pull dist and pump?
iester
12-16-2004 18:16:23
i need to replace valve side oil gasket
Theman
12-17-2004 06:27:54
 Re: pull dist and pump? in reply to iester, 12-16-2004 18:16:23
Only if you absolutely have to. If you decide there's no other way, I recommend you set the #1 cylinder to compression top-dead-center (TDC) and mark the position of the distributor rotor before removing anything. That way it will be easier to set the engine timing upon reassembly.
iester
12-16-2004 18:28:15
it is a ih 350 utility
