which bearing?
iester
12-21-2004 17:59:41
350U i here noise when ta is forward not back. how to fix?
DWV
12-21-2004 18:14:49
 Re: which bearing? in reply to iester, 12-21-2004 17:59:41
One or both bearings on each end of planet carrier in the T/A assembly (if T/A works they
are not turning when in low) or nut has backed
off of T/A clutch carrier.Inspect and repair,my 2 cents.
iester
12-21-2004 18:49:11
 Re: which bearing? in reply to DWV, 12-21-2004 18:14:49
ta work's,quite when pulled back engauge, something noisey when forward.what to do?
DWV
12-22-2004 05:11:34
 Re: which bearing? in reply to iester, 12-21-2004 18:49:11
To make it more clear.The bearings i mentioned
above turn when in high T/A and are stopped in low
T/A ,so if noise is in high its a good bet thats the problem.Get a manual,you need to split tractor.
