W9 power unit
DUANE G
12-23-2004 13:29:19
We think we found a W9 power unit used for irigation pump. Where can I find information about power units and serial and model numbers
Harold H
12-24-2004 09:07:56
 Re: W9 power unit in reply to DUANE G, 12-23-2004 13:29:19
U-9 gasoline, 334.5 cu in, 55 hp @ 1500 rpm, 227 max torque @ 1000 rpm, weight 1760 lbs. UD-9 diesel, 334.5 cu in, 53 hp @ 1500 rpm, 209 max torque @ 800 rpm, weight 2045 lbs. Hp is maximum SAE corrected horsepower of power unit equipped with fan, radiator, air cleaner, and governor, continuous load rating 90% of maximum.
Harold H
potosi
12-23-2004 16:01:59
I have one,it is called U-9. Some were gas,others are diesel.
DUANE G
12-24-2004 08:57:14
 Re: W9 power unit in reply to potosi, 12-23-2004 16:01:59
Dou Know where I can get Information on the serial numbers for the U9
