Super C front rim replacement...how to mount brack
Tyler-MO
12-31-2004 14:51:01
I found a set of original never used super "C" front rims. However, they do not have the brackets attatched to them. I'm wanting to transfer the brackets from my current rims to the new ones. Does anyone have any good ideas with how to do this the best and easiest? Thanks in advance.
Tyler in Missouri
gene b
01-01-2005 05:30:05
 Re: Super C front rim replacement...how to mount b in reply to Tyler-MO, 12-31-2004 14:51:01
You can get the rivets from MILLER TIRE just drill and move one bracket at a time
Brian Schmidt
12-31-2004 16:42:37
I think I would try welding through the holes from the rivets. Get the old ones off and knock or drill out the rivets. Then plug weld them to the wheel. Be sure to get plenty of penetration to the rim and not just fill the hole with weld. Other than that, you could try to find a rivet that would work. Or even an allen head boly maybe.
Some thoughts.
MN Scott
12-31-2004 16:24:38
There are two types of rims for a super C. There is the non adjustable type that has no brackets on it. It just clamps to the cast center hub. Then there is the adjustable type with the mounting brackets. It bolts to the center cast hub.
