pack material
Wes in Ohio
01-05-2005 16:12:52
anybody know what the manual is referring to when it's saying packing material on the water pump. its telling me I need it in the belt pulley nut, I'm just not real sure what their talking about
captiank
01-05-2005 18:19:07
 Re: pack material in reply to Wes in Ohio, 01-05-2005 16:12:52
I believe the packing material they are referring to is water pump packing and it comes in a rope form about a quarter of an inch in diameter. It was used in various types of pumps including water pumps on engines and piston pumps used on individual water systems.
The purpose of the packing is to act as a seal on a moving shaft (either rotating or sliding).
I hope this helps.
riverbend
01-05-2005 17:03:32
On an H, for example, there are 3 soft, fiber split washers that go under the nut and seal against the water pump shaft. Your IH dealer will have them.
Wes in Ohio
01-05-2005 17:15:44
 Re: pack material in reply to riverbend, 01-05-2005 17:03:32
What are they suppose to do and are they necessary
CNKS
01-05-2005 18:31:41
 Re: pack material in reply to Wes in Ohio, 01-05-2005 17:15:44
I didn't know the belt pulley needed it. The water pump will leak like a sieve without it.
