H / M Cultivator
Bubba
01-07-2005 10:12:20
Will a set of front and rear mount cultivators of an H fit an M?
The Dukester
01-08-2005 19:40:41
 Re: H / M Cultivator in reply to Bubba, 01-07-2005 10:12:20
Most,if not all IH cultivators for H's will fit an M, but you probably will have to change the gang spacing because M's are wider than H's in the frame. I've tried 438 4 row cultivators I pushed with my Super M on a real good but not souped up H and it didn't ahndle them very good, not enough oats to get up the hills very fast--2nd gear, working it's heart out. My buddy's Super H pushed the 438s a lot better, but they really belong on a M. That's my experience.
John *.?-!.* cub owner
01-07-2005 15:35:23
We had a set of 2 row steering cultivators on our H that would fit either one by turning the front mounting brackets over.
CNKS
01-07-2005 12:05:17
Yes, that is why they made the H and M in the same configuration, so you shouldn't have any problem. On the other hand some M implements may "fit" the H, but be too big for it powerwise.
jal-SD
01-07-2005 11:03:33
Should. We had a couple of the 2-row models, don't remember the #, think it was a 238, that we used on H's. Neighbor had a 4 row that was same model (only in 4 row) that he used on his M, we put in on an H one year for him to use when his M was busy under the farmhand. (My $0.02 worth. jal-SD)
