444 diesel digital pics please...
fixitforfree
01-07-2005 20:16:36
Any of you able to get me some close up digital pics of the hydraulic pump, lines, hydraulic filter etc. on a 444 diesel? I have a 364 very similar to the 444 but it has a "dual" pump setup and no spin on hyd. filter. I want to at least add a spin on filter and may try to go to a single pump setup if possible. Some good, fairly close pics of the 444 hydraulic system,plumbing and power steering setup would be very helpful. Thanks.
Bernard le mécano
01-09-2005 11:44:42
 Re: 444 diesel digital pics please... in reply to fixitforfree, 01-07-2005 20:16:36
Hi, the 444 have a suction filter in the hydrolic reservoir. The dual pump run the lift system(the large one) the other, run the steering system. A spin-on filter work for a low pressure return line. On high pressure line, a cartridge filter is the best. Bernard le mécano Québec Canada
