1941 Farmall H engine, runs but shoots out oil
Mike Cummins
01-19-2005 15:13:51
We purcahsed and restored this 41 H about ten years ago, the engine at that time worked fine, so we stripped it down put some new paint and tires and a few samll parts but did nothing internaly to the engine. The H will still start and run fine but it spits little oil droplets out the stack. Does anyone know exactly what the problem is. I have heard valve guide or rings, what do you think? Any info would be appreciated.
Scott Swanson
01-21-2005 08:37:13
 Re: 1941 Farmall H engine, runs but shoots out oil in reply to Mike Cummins, 01-19-2005 15:13:51
Dump Champion D21 Spark Plugs in her. The higher heat range will keep the combustion chamber cleaner and less oil-Fowled.
Scott
Eric E
01-20-2005 10:18:29
I have a 48 John Deere A I thought it was oil but it was only carbin. nothing to lose sleep over.
RustyFarmall
01-20-2005 10:16:56
I don't know if this has anything to do with your problem or not but about 40 years ago my dads H did the same thing and dad wanted to know what I had done to it. The first he asked was whether or not I had checked the oil level recently, which I had done, then he wanted to know if I had added any oil, which I also had done. I told him I had added two quarts, just like I did for the 3020 John Deere when it was low. Adding two quarts to an H that is only one quart low will result in oil being spit out the exhaust, a lesson learned quite well.
Michael Soldan
01-19-2005 21:11:12
I think the other guys have it right. Close the shutters and take it up the road about 5 miles and back , that'll clean out the slobber in the muffler, watch you heat guage and once it is in "RUN" open the shutters about a third, if you don't have shutters wrap a blanket around the grill and warm it up...good luck...Mike in Exeter Ontario
MN Scott
01-19-2005 18:28:38
Allan's hit the nail on the head. My SH does the same thing when she's cold, makes a mess on the hood. It's just condesation and some carbon from the muffler. If yours was burning that much oil you would have a cloud of blue smoke and she'd be fouling spark plugs.
jayw
01-19-2005 15:26:30
Mike I also have a 41 H and just as Allen said if you dont load her up and burn the carbon out she,ll spit what looks like oil. I would do some work with her and see if she clears up
Allan in NE
01-19-2005 15:20:03
Hey Mike!
Not to question your judgement, but are you really sure it is oil? My old "H the Harrier" will spit a little black carbon/moisture if I don't work it hard and just putz around with it.
I'd take 'er out and make sure it gets good and warmed up and make 'er pull a little. Maybe there is nothing at all wrong with it.
Dunno,
Allan
