transmission filling
jbcr1028
01-22-2005 15:46:41
The blizzard moved through here last night, i drained the trans on my M international, went to fill back up but not sure where to fill or how much, help please i need it to push snow!!
gusc
01-22-2005 18:51:28
 Re: transmission filling in reply to jbcr1028, 01-22-2005 15:46:41
My SM takes 13 gal in the trans which also includes the rear end.
The hydraulic system takes 6 quarts.
farmallhal
01-22-2005 17:06:00
There are two drains for the transmission and differential which drain together. They look like pipe plugs on the rear very bottom on the centerline of the tractor. The forward one points to the front and is down below the battery or maybe slightly aft. The back one points to the rear and is right below the PTO shaft. My M manual states the quantity to fill the tractor is 13 gals. of SAE-90 transmission lubricant. You should pick you up an owners manual as this is all covered very clearly. When you replace the drain plugs put some teflon plumbing tape on them to eliminate a constant small oil drip. Someone already provided you a post with the fill location on the platform which requires a 3/4" drive socket extension. Good Luck.
John M
01-22-2005 16:48:35
The drain plug for the M tranny is on the back of the tractor just down from the PTO,the plug you removed is to help drain the oil from the front end of the tranny,NOT the hydraulic system,which had its own plug on the bottom of the pump and points down.the fill plug is to the right of the shifter.once you have rained it all out,look on the clutch side of the tranny youll see a plug about half way up,remove it and fill with the lube youre using,should take about 13 gallons!
Verifing.......
01-22-2005 16:51:06
 Re: transmission filling in reply to John M, 01-22-2005 16:48:35
The plug that is on the side is the oil level plug,put the gear oil in until it comes out of that plug.
MagMan
01-22-2005 15:52:21
The fill should be at the right hand side of the shifter On the top cover. Like a 3/4" ratchet fits it. I am not sure on an M but my H took 6 Gal so The M will probly take 8 or more . Fill to plug thats about half way up the side of the tranny on the LH side as your sitting on seat. JON
jbcr1028
01-22-2005 16:11:03
 Re: transmission filling in reply to MagMan, 01-22-2005 15:52:21
theres a plug about 6 inches up from the bottom on the left side straight down from the fuel tank shut off. the plug that i drained it from points to the front of the tractor, this the right drain? thanks
John *.?-!.* cub owner
01-22-2005 16:24:25
 Re: transmission filling in reply to jbcr1028, 01-22-2005 16:11:03
It's been a while since I dealt with one, but your description sounds like the hydralic system, not the transmission. The transmiion is under the deck at your feet, and ends at the front of the deck.
MagMan
01-22-2005 16:29:10
 Re: transmission filling in reply to John *.?-!.* cub owner, 01-22-2005 16:24:25
Does it have a belt drive ? Thats kinda still the tranny so the check plug would be on the L side under that I guess.If its got a belly pump for the HYD I beleve the drain plug faces the rear for that. Its to cold to go out and check all for sure. JON
01-22-2005 16:33:28
 Re: transmission filling in reply to MagMan, 01-22-2005 16:29:10
I told you it had been a long time, and I'll admit my memory is not good.
MagMan
01-22-2005 16:39:18
 Re: transmission filling in reply to John *.?-!.* cub owner, 01-22-2005 16:33:28
We all have those problems sometimes JOHN,I have a cub out in the garage but I cant tell you where anything on that is with out looking. But Ill bet you can. JON
MagMan
01-22-2005 16:22:55
Yes that sounds right you drained the tranny.There is a larger drain in the rear at the bottom of the case that points to the rear that will drain the final drive or bull gears. So if thats all you drained it may not take much to fill it I dont know if you would have got it all out that way. JON
