THOMPSON HYDRO REBUILD KIT WITH GEARS
JOSSETTE
01-29-2005 08:50:02
WHERE,IF ANY,CAN I GET A KIT FOR A 400 FARMALL??
CNKS
01-29-2005 12:15:04
 Re: THOMPSON HYDRO REBUILD KIT WITH GEARS in reply to JOSSETTE, 01-29-2005 08:50:02
What's wrong with it? Seals and gaskets can be replaced (Case-IH dealer) But, if the gears are shot, you are probably going to need a rebuilt pump. Costs about $550.
JOSSETTE
01-29-2005 21:58:04
 Re: THOMPSON HYDRO REBUILD KIT WITH GEARS in reply to CNKS, 01-29-2005 12:15:04
would the seals help TO the build the pressure up. I HAVE NEVER HAD ONE APART TO KNOW WHAT GOES ON.
CNKS
01-30-2005 09:29:21
 Re: THOMPSON HYDRO REBUILD KIT WITH GEARS in reply to JOSSETTE, 01-29-2005 21:58:04
Seals won't help if the gears or case are worn -- take it off, take it apart and look at it, it is a very simple pump. The hardest part will be reattaching the lines.
CNKS
01-29-2005 12:35:09
I hadn't read your post below -- better answers than mine -- Try Steel Wheel Ranch as suggested, if you haven't already 785-548-7437. Mike will give you a 30 day warranty -- enough to see if it works right. VB has them for about $550.
