Zenith Carb for Super A
Pete7
02-03-2005 12:03:51
I have two carbs for my Super A. Both are Zenith carbs and both are for a Super A, but one carb has the adjustable main jet. This carb seems to give me a little more power. Is this just my imagination or is there really some difference in the carb that could account for this?
Pete
CNKS
02-03-2005 18:43:47
 Re: Zenith Carb for Super A in reply to Pete7, 02-03-2005 12:03:51
Actually, the C113/123 tends to run rich, you may be getting more power because you can actually adjust the thing.
JOSSETTE
02-03-2005 16:45:00
the kerosene carb has a bigger jet to allow the thicker fuel to get through. that tractor should have no problem pulling but watch the fuel gauge.
kendall
02-03-2005 13:51:03
According to the manual, the distillate and kerosene carburetors had a main jet adjustment and the gasoline carb had only idle mixture adjustmant. You can run the d/k carb with gasoline by adjusting the mixture screws until the engine runs smooth. Maybe the d/k carb has a bigger bore, or more tuneable due the main jet adjustment and would explain the preceived extra power.
