24 volt om farmall deisel?
Dave From MN
02-04-2005 05:51:52
Any one ever wired on of these that use 2 6 volt batts so that when cranking it uses 24 volts to crank the engine. but other wise uses 12 for everything. A freind saidhe had it done on a perkins he had and I makes it start like a gas almost. If hear no negatives I may try it if I can the wiring diagram and parts used. He says no either or anything even in cold cold weather.
El Toro
02-04-2005 17:40:11
 Re: 24 volt om farmall deisel? in reply to Dave From MN, 02-04-2005 05:51:52
Here's how you get 24 and 12 volts. Hal
+ 24 volts starter ! ! !_ ! ! ! ! + 12 volts lights &etc ! ! ! ! !_ GRD
JOSSETTE
02-04-2005 13:40:09
if you took 2 -12 volt and hooked them with a lead(3/8 i-let) positive to positive and neg to neg you will not have to change anything. 12 volts of bat and double the cranking.
Aces
02-04-2005 11:27:03
Dave JD did use it for years and it is a pain more like a hemroid if you don't know what your doing you got a MESS some things + and some things - have to hock some things on one side and some on other. I would take the IH 12V any day. Not a true 24V like the 12V one ground and one hot.
EricB
02-04-2005 09:44:33
Dave:
The guys are right a lot of semis run on the system you want. Why don't you take an hour and drop down to a tractor trailer service centre. Bet the guys there could draw it out on the back of an envelope for you!
Dave Wilguess
02-05-2005 21:34:04
 Re: 24 volt om farmall deisel? in reply to EricB, 02-04-2005 09:44:33
I will make a suggestion stay away from the 24 volt if your deverter shorts out then you have a wire fire. I use 2 12 volt wire pos. to pos and neg to neg and I always use the gel batterys on all deisels it just makes life easer.
Dave
El Toro
02-04-2005 06:33:57
The military has used 24 volt systems for years.
Those diesels still need someway to preheat them prior to startup when it's very cold. Coolant or
block heaters are an excellent choice so you don't to use so much ether.
The Soviets have used them for years and they start like summer time at -65 degrees. Hal
Allan in NE
02-04-2005 05:54:27
Hi Dave,
Yep, John Deere has done that for years.
Allan
Bob
02-04-2005 06:36:08
 Re: 24 volt om farmall deisel? in reply to Allan in NE, 02-04-2005 05:54:27
Allen, the Deere system, on the ag line anyway, was a true 24 Volt system. It charged the batteries at 24 Volts AND the starter operated off of 24 Volts. The 12 Volt lighting and gauge loads were split between the two halves of the system.
What Dave is talking about is using a series-parallel switch so the batteries are connected in PARALLEL for charging at 12 Volts and in SERIES for starting, at 24 Volts.
A diagram will NOT be hard to come by, because there were TONS of semis that used this system some years back, as well as construction and marine applications.
There is a LOT of wiring and detail needed to make this conversion, though!
Doug in OR
02-04-2005 08:07:23
 Re: 24 volt om farmall deisel? in reply to Bob, 02-04-2005 06:36:08
The key here, Bob, is that you used the word "split". It is essential that you draw the same amount of load off one 12 volt side as you draw from the other. If you only connect your non-starting load to half the 24 volt battery bank, you will end up with uneven charging. How evenly you split the load will determine what kind of luck you have with this configuration.
Allan in NE
02-04-2005 06:53:16
Heck, I dunno Bob,
My hired man had a 5020 and he told me it charged 12 and cranked 24. Didn't pay much attention to it, tho.
Allan
Bob
02-04-2005 07:03:25
 Re: 24 volt om farmall deisel? in reply to Allan in NE, 02-04-2005 06:53:16
If the 5020 REALLY charged 12 Volts and cranked 24, it was NOT a factory setup.
Dave From MN
02-04-2005 05:58:00
Then thats what I shall try. Just redid all the lights on the 544 last night. What a difference. I really want to get away from using either as the it only has about 3200 hours buts crankc over sooo slow.
Dave From MN
02-04-2005 05:53:42
I forgot to mention the tractor would be equiped with 2 -12v Batts as opposed to 6v
houndog
02-04-2005 06:08:18
 Re: 24 volt om farmall deisel? in reply to Dave From MN, 02-04-2005 05:53:42
be careful you dont mess up your starter and silonoid as you are doubling your voltage, unless you buy a 24v silonoid and have your your starter rewound
Dave From MN
02-04-2005 06:35:40
 Re: 24 volt om farmall deisel? in reply to houndog, 02-04-2005 06:08:18
Thanks. I know he said ya change the solenoid, but I belive the starter stayed the same since apparently ya never have to crank more that 5 sec.
brtx
02-04-2005 07:00:25
 Re: 24 volt om farmall deisel? in reply to Dave From MN, 02-04-2005 06:35:40
white and freightliner nad the series paralel switches in the 60s.the old motors manuals had diagrams if my memory is correct.there was also a lot of problems with the series paralell switch.more connections and learning how to trouble shoot.
