farmall M antifreezes leak on the left side of the
Ryan Carney
02-05-2005 17:50:29
found a leak when runing the farmall m in the middle of the engine on the left side right behind the carb and muffler. can a new plate be ordered to fix the problem or can i weld?
DWV
02-05-2005 18:03:35
 Re: farmall M antifreezes leak on the left side of in reply to Ryan Carney, 02-05-2005 17:50:29
You can get a new plate.When you remove the one from tractor it will look worse on inside.Watch on the 5/16 bolts there easy to twist off since some of the holes go into collant and get rusty.
Al in Mn
02-06-2005 14:09:51
 Re: farmall M antifreezes leak on the left side of in reply to DWV, 02-05-2005 18:03:35
I got one from an after market supplier for $28 but I had to use the grinder and file to get it to fit properly.
CNKS
02-05-2005 18:11:49
Case-IH has them, probably much cheaper from other sources. Think I paid $100+ from Case-IH.
