hydr. filter 666 international
Jon in Ohio
02-21-2005 12:25:01
going to change oil and replace filter.how much hy.tran do I need to get.
Duane NC OH
02-21-2005 17:01:22
 Re: hydr. filter 666 international in reply to Jon in Ohio, 02-21-2005 12:25:01
my 686 holds 16 gallons of hy-tran. should be close to your 666.
hth
Duane
Dave From MN
02-21-2005 13:28:06
My "70 544 Hydro takes 20 Gallons to be topped off. Make sure you get all the fluid out from all the drain holes and follow maintenance recomendation for the process.
Hugh MacKay
02-21-2005 13:03:15
Jon: Been close to 20 years, so basically I'm testing my memory here. My thoughts are 16 gallons. Don't take that as gospel, I may be wrong, but I'm betting guys will jump on me quick if I am.
Stickler
02-21-2005 17:36:45
 Re: hydr. filter 666 international in reply to Hugh MacKay, 02-21-2005 13:03:15
yep, manual says 16 gallons. Question though. last time i did mine, I had the oil drained already. Can you change the filter without dropping the oil?
Hugh MacKay
02-21-2005 19:15:49
 Re: hydr. filter 666 international in reply to Stickler, 02-21-2005 17:36:45
Stickler: Yes you can change filter without changing oil. Best to have a catch pan as you will loose about a quart. More the mess than volume of oil you loose.
Stickler
02-22-2005 03:19:30
 Re: hydr. filter 666 international in reply to Hugh MacKay, 02-21-2005 19:15:49
Thanks, Hugh!
