Help lifting out TD-9B steering clutch
Jayme
02-21-2005 13:57:06
I am trying to lift out the right track steering clutch. There is not enough room, I need another 1/4 inch of clearance. My shop manual mentions a angle compression tool, but the problem is that I do not have one or know what it does. My guess is that it compresses the clutch spring to give me a little more room to lift out the clutch assembly.
Does anyone know what the angle compression tool is or have any other great tricks?
bruce christian
02-22-2005 18:22:26
 Re: Help lifting out TD-9B steering clutch in reply to Jayme , 02-21-2005 13:57:06
OMG do not take the bolts out that keep the clutch pack depresses. I have heard rumors about them letting go.
hector gemme
02-21-2005 14:33:19
hi their no tricks no magic tool you taque off the bearing adjuster nut lock and you turne bearing adjuster on reight it give little more space good luck .I have some td9 parts HECTOR
Jayme
02-22-2005 18:54:07
 Re: Help lifting out TD-9B steering clutch in reply to hector gemme, 02-21-2005 14:33:19
I tried turning the bearing adjuster to give more space, it appears to be on all of the way. I successfully removed repaired and replaced the other side without ever running into this problem. Any other ideas.
hector gemme
02-23-2005 15:39:08
 Re: Help lifting out TD-9B steering clutch in reply to Jayme, 02-22-2005 18:54:07
HI I check in service manuel some you have to prying bearing cap for more space god luck .HECTOR
