OT: update on the hay rack builds
Kelly C
02-25-2005 18:56:18
third party image
Took the advice of some people from the forums. I added these braces to the cross members to strengthen them. This photo is from the next rack I am working on but went back and retrofitted these to the other racks I have done.
hayhauler
02-26-2005 17:56:12
 Re: OT: update on the hay rack builds in reply to Kelly C, 02-25-2005 18:56:18
I'd like to see the pictures of what you had before, but I can't find it. Did you have a more complete picture of your hay racks?
Kelly C
02-26-2005 19:36:22
 Re: OT: update on the hay rack builds in reply to hayhauler, 02-26-2005 17:56:12
Just pop into my web site. In the left pane find the link to hay rack build. Might have to scroll down a bit to find it.
Nebraska Cowman
02-26-2005 04:11:24
That looks better Kelly, I probably put one more bolt in the lower end. Then I'd recomend cross pieces between the main bed pieces too. in you other post you showed one at one end and it was a smaller timber. Id use the same width (height) as the bed pieces. fasten it with angles and bolts too. You don't want that frame to roll and twist because it will try to lay over on you.
scotty
02-26-2005 03:47:40
Hey Kelly, That old angle iron does come in handy at times dont it!
scotty
