Fender/Transmission felt pad
Robert Nicholas
02-28-2005 13:30:23
I'm rebuilding/restoring a 100 and need to know where I can get the felt pad that goes between the left fender and the transmission. When I took it apart it was melted into nothing and the parts places say it's no longer available. Any suggestions? Can I make one out of something else available?
Also, I noticed that the left rear rim is 8 inches wide and the right rear rim is 9 inches wide. Is this right? The rim clamps are different so I suspect some sort of change-out somewhere in time.
My grandfather farmed 80 acres with this tractor so it's seen lots of service.
Georgia Boy
03-01-2005 07:02:26
 Re: Fender/Transmission felt pad in reply to Robert Nicholas, 02-28-2005 13:30:23
I bought a sheet of felt from McMaster-Carr and cut it to fit for my A.
CNKS
02-28-2005 19:12:39
IMO, those things are moisture traps, you might be better of without it.
JOSSETTE
02-28-2005 18:25:10
If there is anywhere they rebelt conveyors around there ,,you can pick up some scraps of any thickness for little-to-nothing.
Dixieland
02-28-2005 16:25:41
There used to be a 4" x 8" x 3/4" black felt board used as a vapor barrier on brick veneere house framing. Might be able to find some at a salvage yard or lumber yard.
Dixieland
02-28-2005 16:27:56
 Re: Fender/Transmission felt pad in reply to Dixieland, 02-28-2005 16:25:41
4' x 8' x 3/4"! Sorry bout that.
RLN
02-28-2005 18:01:14
 Re: Fender/Transmission felt pad in reply to Dixieland, 02-28-2005 16:27:56
Thanks. I started to put it back on without anything but it's a bad place to get dirt packed in and a good rust started (worse than was alread there).
RAW in IA
02-28-2005 15:43:03
Don't know about the different rim sizes, but I think I would cut a piece of inner-tube or something similar to use on the fender.
