Installing Starter in W4
John White
03-03-2005 15:55:41
Hello All, Anybody able to give me some pointers of how to get the starter into its place. The tractor has never had a starter and I've been cranking for 20 yrs. Decided to get a starter but I can't fit it in. Do I have to take the pulley casing off or do I have to split the tractor. Any help or points will gratefully received.
Thanks
John W.
John White
03-04-2005 07:45:35
 Re: Installing Starter in W4 in reply to John White, 03-03-2005 15:55:41
Thanks for the information. It looks like the pulley housing option is the best bet.
Everyone have a Good Day!
Thanks,
John W.
EricB
03-04-2005 04:55:00
Yep!
Its not really a big job to remove the pully housing. Four bolts, one in each corner and then the two long ones in the centre. I just slide the housing over since it is a real brute to lift off completely. Takes about 20 minutes.
John M
03-03-2005 18:11:50
Experoment first.Sometimes simply turning and tilting them in just the right way will let them slide into place.You DO NOT have to pull the belt pulley,although it may be easier,you can simple remove the front two bolts on the clutch cover and loosen as much as possible the rear ones,pry up on the front of the cover on the starter side just enouhg to get it in.There is one bolt directly under the starter that will need to be in a posistion to make it easier to get in with the starter on top of it,youll fiqure out what I mean.I just simply used a shorter bolt and that wasnt a factor.
parts man
03-03-2005 16:02:58
In my experience, I"ve had to remove the pulley housing off the tractor to get the starter into place. A bit of a PITA, but it seems to be necessary.
hector gemme
03-03-2005 17:14:06
 Re: Installing Starter in W4 in reply to parts man, 03-03-2005 16:02:58
HI Last year I change mine and I remove the pulley housing .HECTOR
