W-30 governor
dlp
03-08-2005 17:50:04
Discovered that the cross shaft that goes in front of the engine was too short. I used one out of a F-30 because my original was worn in the eyelet. I didn"t know they were different. Probably not supposed to be different, but they were. By the way, did some early W-30 throttle linkages go down to the carb instead of the governor?
Sloroll
03-08-2005 18:27:07
 Re: W-30 governor in reply to dlp, 03-08-2005 17:50:04
Thought it had to be sumthin like that. Did you measure both shafts to make sure. It seems that those cross arms can seperate somewhat and not snap fully back. I don't know about the early throttle shaft.
