International oil/hydraulics
reid man
03-09-2005 19:35:52
I just purchased a 67 IH 424. I want to change all of the fluids. I believe the the hydraulics will take hydraulic oil. It looks like the tranny and rear diff takes gear oil? What weight and how much?
Haas
03-10-2005 06:04:28
 Re: International oil/hydraulics in reply to reid man, 03-09-2005 19:35:52
The 424 has a separate reservoir for the hydraulics. That is it does not use the transmission oil for the hydraulic system. Therefore, you can use tractor fluid (HyTran) in the hydraulics, and if you want to, gear oil(any 80-90W or 90-140 oil will work) in the transmission. However, you can also use the HyTran in the transmission and that may be best to avoid any confusion. I don't know the capacities, but I think the hydraulics are about 3 gallons. I owned a 424 for a few years. Good utility type tractor. Main reason I sold it was no power steering. Note also that the early models of the Mahindra tractors are almost exact copies of the 424 and many parts interchange. Mahindra parts are cheaper than from IH.
farmalljim10
03-10-2005 04:16:01
It should all take hy-tran or equiv.I dont know the amount. Jim
