degrease me
Dente
03-11-2005 17:23:26
Need to know if anyone has a fairly easy way to degrease an engine and frame before paint is applied. My MD is loaded. Figured someone must have a half way effecent way to go about it. Thanks
El Toro
03-12-2005 10:34:18
 Re: degrease me in reply to Dente, 03-11-2005 17:23:26
Find someone with a steam jenny that uses a commerical detergent. We used them to remove
cosmolene. A grease most military parts are
packed with before shipment. Hal
JJK
03-11-2005 19:34:27
We use a product at work that's put out by Zep and we've also used one by Davies. Both were degreasers and worked really good and it also helps to use a pressure washer that has hot water to melt the grease. These products will stain paint if left on to long and will take your finger prints off your hands after a while so be carefull when using this stuff.
thejdman01
03-11-2005 18:47:40
fine grit grinder wheel, cheap got to sand it any ways will definily cut through grease
DAVE NE IA
03-11-2005 18:42:04
In the old days of cheap gas, I used a mix of fuel oil and gas. I have a concrete form oiler / sprayer (gas will break most sprayers with rubber parts. I just spray the mixture on avoiding rubber parts, let it soak and respray the very old dried on areas for a few days. Then power wash with a dirt buster nozzle with very hot water and final wash with a harsh detergent. Common sence is a must. Dave NE IA
Jim in NC
03-11-2005 18:41:11
I stripped a tractor with oven cleaner from the dollar store. It worked great. If you can do it on a damp, foggy day and keep re-applying the cleaner so it stays moist, it will also remove the paint. I would use a pressure washer first to remove some of the loose gunk before using the oven cleaner.
Gordo
03-11-2005 18:14:39
Find your local steam or hot pressure wash guy. GordoSD
PAULIH300
03-11-2005 17:53:26
Knights Products makes a product called "Grease-Off".It disolves grease.Thats its only purpose.It comes in spritzer bottles,gallons,and 5 gallon pails.I have seen it used on greasy shirts,pants,and carpeted floormats with excellent results.
CNKS
03-11-2005 17:45:16
Oven Cleaner, paint strippers, pressure wash, wire brush -- there is no easy way. Unless you just want to wash and spray like some people do.
dr.sportster
03-12-2005 05:31:14
 Re: degrease me in reply to CNKS, 03-11-2005 17:45:16
You have to do a pretty thourough job for paint its going to be more hands on than just applying some degreaser and spraying off with a hose.Work the degreaser in as much as possible.SU100 motorcycle degreaser is good Gunk is good but smells bad on a hot engine.Maybe get a box of throw away rags also.Just keep scraping away at it.
dr.sportster
03-12-2005 05:45:08
 Re: degrease me in reply to dr.sportster, 03-12-2005 05:31:14
Sorry CNKS,meant this to be under the other guys post.
