806 questions
Corey R
03-12-2005 15:46:46
Is there anything special about a gold 806 emblem or is that the way they came? It is a 1965 model. Also anyone know how much it costs on average to go through the injection pump? This one is leaking from where the throttle shaft goes through and I believe it is a IH pump, not a Roosa style.
Thanks
Corey
chadd
03-14-2005 09:20:36
 Re: 806 questions in reply to Corey R, 03-12-2005 15:46:46
Gee, I have not seen an 806 with a gold nameplate. Our 1964 806 has a silver one. I know that the 1206 came with both a silver plate and a gold plate and that the gold plate model was supposed to have more power. I don"t know if that is true or not. Maybe it was a special thing or a promotion? Beats me, if you find out, post it here because I find that really interesting.
ejr-IA.
03-13-2005 10:03:37
Would think a 65 has a roosa pump.A couple o rings should fix the leak on the shaft get at a dealer or pump shop.You can fix that with out removeing the pump.
Larry806
03-12-2005 18:33:18
Here in central Ohio Roosa Master pumps rebuilt cost 525 exchange
JJK
03-12-2005 16:45:53
These old style inj. pump are obsolete and very expensive to repair if they can be repaired. I've switched one over to a Roosa Master pump just cause it was cheaper to go that way.
