firing order for M
Cold Country Bo
03-15-2005 17:12:21
My 10 month old colt just ripped and chewed off the spark plug wires from the distributor on my Farmall M. I'm sure the number 1 cylinder is at the front of the engine. Can someone tell me which is number one on the distributor so I can rewire. Thanks, Dan
Cold Country Boy
03-16-2005 15:31:06
 Re: firing order for M in reply to Cold Country Boy, 03-15-2005 17:12:21
To all who replied regarding my firing order on my M I appreciate very much. I believe the best advice is to determine where the rotor is pointing at the top of the compression stroke of the number 1 cylinder. Thanks again.
NDS
03-16-2005 06:41:43
Some of these old tractors have been worked on by ameature mechanics over the years and they did not allways go by the book. Have seen Number 1 wire in every position on cap if you wire it correctly and it will not start nebraka kirk had correct procedure.
F-Dean
03-15-2005 19:03:20
Also watch the direction of rotatiom of the distributor, otherwise, it will not run very well.
gascolator
03-15-2005 18:33:11
And for 4-cylinder engines (ours included) it is almost always 1-3-4-2
farmallhal
03-15-2005 18:49:52
 Re: firing order for M in reply to gascolator, 03-15-2005 18:33:11
A WWII bomber pilot would say No. 1 is 2 o'clock high looking from the rear towards the front.
Dick Davis
03-16-2005 04:24:30
 Re: firing order for M in reply to farmallhal, 03-15-2005 18:49:52
Nope! 12 o'clock level or 12 o'clock low - but never high from the tractor seat. My nickel Dick Davis
CNKS
03-15-2005 17:44:07
It should be marked on the cap--but #1 is the top right viewed from the rear.
2 1
4 3
nebraska kirk
03-15-2005 17:27:15
Turn the engine over until the No. 1 cylinder is at the top of a compression stroke. Then see what direction the roter is pointing in relation to the distributer cap, and that is the #1 position.
