posituve or negitive
Donna
03-17-2005 09:24:59
I have a 1955 IH utility 300 and have a condensor problem - it eats them - so I was wondering if the polarity is wrong. It was converted to 12 volt with
Neg ground - would reversing the coil polarity help this problem Thanks Gary
Doug in OR
03-17-2005 15:41:10
 Re: posituve or negitive in reply to Donna, 03-17-2005 09:24:59
I vote for Bob M's answer. The problem could also be a bad coil.
dr.sportster
03-17-2005 11:25:38
Besides keeping points from burning the condeser does aid in voltage buiding in the coil secondary windings as Bob M stated and the only thing I could possibly think of is a coil mismatch to your system.Condensors are fairly trouble free.Some coils will require larger microfarad rating condensers than others.Is it the stock coil?
dr.sportster
03-17-2005 11:10:22
What are the points doing.Condensors normally provide thousands of miles or many hours of service.Faulty ones burn the points.Are you testing them.All electrical troubleshooting requires a fully charged battery.To be honest this one is unusual.Bad points dont ruin them either.What ele is it doing and why are you concluding bad condesers?
Allan in NE
03-17-2005 10:33:36
Hi Gary,
What do you mean, "It eats 'em"? Is it shorting them out?
Can't ever remember having a "bad" condenser. Some that weren't the right size and throw, etc., but don't remember a shorted one on an old points type system.
Don't quite understand the whole of your problem, I guess.
Allan
El Toro
03-17-2005 10:25:15
Is there a ballast resistor installed in that ignition circuit? They're used to drop the voltage. I do not think the negative ground would cause the condenser failure. Hal
Bob M
03-17-2005 10:22:59
Ignition condensors are polarity insensitive - they'll work and last fine on either polarity.
Has a ballast coil been added to the primary supply to the coil, or has the original coil been swapped for a "12 volt" coil? If not, this could possibly account for your the condensor failures.
scotty
03-17-2005 11:29:27
 Re: posituve or negitive in reply to Bob M, 03-17-2005 10:22:59
Hi Bob, I borrowed some of your words from a previous post on polarizing, hope you didnt mind, I usually say in the post that was you talking but forgot in that last post. Happy St Pats Day!
scotty
