Mike, I'm not sure what numbers you found. The serial number for an H should start with the letters FBK and the super H would start with SH. The serial number should be on an aluminum plate riveted on the left side of the bell housing. The valid suffixes for the H and M series are below: X 1 Gasoline X 1 A Gasoline – Low Speed Gears X 1 B Gasoline – 5000 ft. Altitude X 1 C Gasoline – 8000 ft. Altitude X 1 E Gasoline – 5000 ft. Altitude – Low Speed Gears X 1 F Gasoline – High Speed Gears X 1 G Gasoline – High Speed Gears – Low Speed Gears X 1 H Gasoline – High Speed Gears – 8000 ft. Altitude X 1 J Gasoline – 7 m.p.h. High Speed Gears – 5000 ft. Altitude X 1 L Gasoline – 5000 ft. Altitude – 7 m.p.h. 4th Speed – Low Low Speed X 1 M Gasoline – 8000 ft. Altitude – Low Low Speed X 1 N Gasoline – 8000 ft. Altitude – Low Low Speed – 7 m.p.h. 4th Speed X 2 Modified X 3 Kerosene X 3 A Kerosene – Low Speed Gears X 3 B Kerosene – 5000 ft. Altitude X 3 C Kerosene – 8000 ft. Altitude X 3 D Kerosene – High Speed Gears X 3 G Kerosene – 7 m.p.h. High Speed Gears – 5000 ft. Altitude X 3 H Kerosene – 7 m.p.h. Low Low Speed X 4 Shop Mule X 5 5000 ft. Altitude X 5 A 5000 ft. Altitude – 7 m.p.h. 4th Speed X 6 Low Speed Gears X 6 A Low Speed Gears – Starting or Lighting X 6 B Low Speed Gears – High Speed Gears X 6 C Low Speed Gears – 5000 ft. Altitude X 8 8000 ft. Altitude X 9 High Speed Gears X 10 10,000 ft. Altitude X 11 Engines with Undersize Crankshaft X 11 S Engines with Undersize Crankshaft (Service) X 14 Starting or Lighting X 14 A Battery Ignition with Starting or Lighting and Adjustable Front Axle X 16 Over-Center Hand Operated Clutch X 17 Distillate X 17 A Distillate – 5000 ft. Altitude X 17 D Distillate – 8000 ft. Altitude X 18 Unlisted Feature X 19 Special Transmission X 20 Cotton Harvester X 20 A Cotton Harvester – Gasoline X 20 B Cotton Harvester – Kerosene X 20 C Cotton Harvester – Diesel X 20 D Cotton Harvester – Gasoline – Low Low Speed X 20 E Cotton Harvester – Distillate – 5000 ft. Altitude X 20 F Cotton Harvester – Gasoline – 5000 ft. Altitude Pistons X 21 7 m.p.h. Transmission – 8000 ft. Altitude X 22 Adjustable Front Axle (Heavy Duty) X 22 A Adjustable Front Axle X 23 Auburn Clutch X 24 Nonadjustable Front Axle Hope this helps. Larry
