300 utility Steering
Jim Erke
03-27-2005 05:35:39
I bought a 300U with bad steering gear box. Upon rebiulding it I found only one it takes two I call it a outer bearing race the book calls it a steering wheel cam cup #68060H (same as #364618R1). My trouble is I can not find one in my area. Can someone tell me where to find one or what I can do?
THANKS ALOT
MD Wa.
03-27-2005 07:31:06
 Re: 300 utility Steering in reply to Jim Erke, 03-27-2005 05:35:39
Jim. If you have the old bearing I would thing any large bearing house should be abie to match yours. I have seen then use the IH parts number and come up with the right bearnig. Morgan
Jim Erke
03-27-2005 08:20:41
 Re: 300 utility Steering in reply to MD Wa., 03-27-2005 07:31:06
I tried Motion Ind. but they could not match it up. But they had the 5/16" ball bearing for alot less .10 each
TDK
03-27-2005 06:41:48
Join the club. Ours had balls missing. Couldn't get a new assy. through dealer. Did get new balls though. We now need the upper column bearing. You might place an ad in classified ads and find a gearbox that has bad gears in it, to salvage the part from.
