Regular roundspoke welding
KevinH
03-31-2005 19:29:26
OK guys, I need some good advice. It'll be a while before I'm ready for my front wheels, but I want to start working on them when I can't do anything else. I have a set of F & H round spokes(16") for my Regular. The rims are shot and will need to be replaced. I had this done several years back on an F-20 Set I modified to fit my F-12 but it was not too hot of a job. Anybody done this that can recommend the right rim to use, best way to cut old ones off, new ones on, etc? Thanks in advance...Kevin
JD @ Antique Acres
04-01-2005 07:07:36
 Re: Regular roundspoke welding in reply to KevinH, 03-31-2005 19:29:26
I have found that you can find good used ones for alot less than the cost of rerimming.
I have one that is useable that just needs some straightening, Intersted? I also have one that needs a rerim.
ET
04-01-2005 04:39:18
There is an outfit called Detwiler Tractor Parts that will rerim F&H wheels. Fronts are $149 each rears are $475 each. 715-659-4252 They are in Spencer, Wisconson.
