Crankshaft/Pilot Bearing Felt Wick F-20?
SproutW
04-02-2005 10:40:34
In the middle of my engine assembly for my F-20. I noticed the felt wick that goes through the crankshaft and lubricates the clutch pilot bearing is missing. Guess the engine shop removed it for some odd reason to grind the crankshaft. Called Rice Equipment and they don't have it. I've already had to make some gaskets but I have no idea where to search for the felt material to make the wick. Anyone out there already solved this problem in the past or have any ideas. Thanks.
Mike S 806/H
04-03-2005 12:27:18
 Re: Crankshaft/Pilot Bearing Felt Wick F-20? in reply to SproutW, 04-02-2005 10:40:34
tap the hole with a pipe tap then plug it, Grease the bearing.
SproutW
04-03-2005 12:38:22
 Re: Crankshaft/Pilot Bearing Felt Wick F-20? in reply to Mike S 806/H, 04-03-2005 12:27:18
I take it you have had no problems with this modification. I bet someone had a sealed bearing that would fit and keep me from having to grease it.
Nebraska Cowman
04-02-2005 15:01:04
i'd try some cotton rope.
SproutW
04-02-2005 19:17:22
 Re: Crankshaft/Pilot Bearing Felt Wick F-20? in reply to Nebraska Cowman, 04-02-2005 15:01:04
Thanks Nebraska, sounds like a good idea to me. I'll find some and see how it works.
