Super c surging/hunting
chris in Ontari
04-03-2005 15:07:30
Hi everybody, I rebuilt a super c a couple of years ago, and have had a constant problem with it surging/hunting. Today I adjusted the float in the carb and cleaned out the bumper spring adjustor on the gorvernor(full of crud). All of the other settings appeared to be correct When I started it it ran fine with no surging, but after shutting it off and starting it again it did it again, but only at half throttle or above.
Any suggestions?
BillWV
04-05-2005 05:44:40
 Re: Super c surging/hunting in reply to chris in Ontario, 04-03-2005 15:07:30
Chris,
Did you adjust the governor stop? If you tighten it up, it should stop the surging. If you get it too tight it will idle too fast.
Good luck,
Bill
gene b
04-03-2005 18:48:16
Quick fix is just add a spring to the carb throttle linkage.
Farmallkid From Ont,
04-03-2005 18:12:21
Not sure about your probablem, but was wondering where you live? I am from Ridgetown, an hour west of london.
chris in Ontario
04-04-2005 15:05:46
 Re: Super c surging/hunting in reply to Farmallkid From Ont,, 04-03-2005 18:12:21
I live in Powassan about 20 min. south of north bay
George 2
04-03-2005 16:36:18
Slop in the governor is your problem. Take the governor apart, change out the spring and check the entire linkage to ensure no slop. also check the weights are free but not sloppy.
