Gas Gauge
chadd
04-05-2005 10:03:10
On our 966, the fuel tank overflowed when we filled it up and the fuel gauge quit working soon after. It is really weird. When you turn the key, the needle moves up a little bit, and when you hit a big bump, it will bounce. However, it refuses to show the level in the tank. Is the ground bad or something? Any help would be appreciated.
Allan in NE
04-05-2005 12:34:50
 Re: Gas Gauge in reply to chadd, 04-05-2005 10:03:10
Chadd,
Run a ground wire jumper to the SENDER SIDE of your gauge. That should force it to read full.
If it does, you've got a bad wire, connection or sender.
If it does not, you've got a bad gauge. (Problem is usually in the sender side, however).
Allan
chadd
04-05-2005 12:49:55
 Re: Gas Gauge in reply to Allan in NE, 04-05-2005 12:34:50
This might be a dumb question, but is that the side of the gauge with the wire that is connected to the sensor in the tank? I have never looked at the back of it, how many poles are on the back of the gauge?
Allan in NE
04-05-2005 12:59:35
 Re: Gas Gauge in reply to chadd, 04-05-2005 12:49:55
Yep,
Most of 'em have three terminals, but one is just a ground for the case. Don't ground that 12 volt feed or you'll warm 'er up.
Ground the sender terminal.
Allan
chadd
04-05-2005 13:09:26
 Re: Gas Gauge in reply to Allan in NE, 04-05-2005 12:59:35
Thanks. Now I just have to find time to get the cover off from under the cab to try it.
Allan in NE
04-05-2005 13:19:15
 Re: Gas Gauge in reply to chadd, 04-05-2005 13:09:26
Oh, I didn't realize you had a cab.
Get a stick. :>)
Allan
chadd
04-05-2005 13:45:11
 Re: Gas Gauge in reply to Allan in NE, 04-05-2005 13:19:15
Already have one. Broke a branch off of a nearby tree right after the gauge quit. What I really need to find is a stick that will read as I drive! Then, I won't bother fixing the gauge.
scotty
04-05-2005 11:51:10
third party image
Hey Chadd does it l;ook like this?
scotty
chadd
04-05-2005 12:25:49
 Re: Gas Gauge in reply to scotty, 04-05-2005 11:51:10
On that gauge, the needle would sit right under the line between 0 and $25.
