12 V coil, which one to buy at NAPA - farmall H
arod
04-07-2005 12:30:12
Hello, Needing a hot, cheap 12V coil to put on my H. Ford, Chevy, etc...? What have you fellas bought at NAPA for this purpose? thanks
ronee
04-08-2005 00:23:57
 Re: 12 V coil, which one to buy at NAPA - farmall in reply to arod, 04-07-2005 12:30:12
napa #ic14sb..
Paul in Mich
04-07-2005 18:42:45
arod, A NAPA coil will work just fine on your H. It is an aftermarket item, and does not match the original coil, but it will function just as well. You can get the original type coils from several sources, but they probably cost twice as much as the aftermarket coil from NAPA.
John M
04-07-2005 16:31:22
69 Ford F100 with 302,ask for the one with built in resistor.
JOSSETTE
04-07-2005 16:26:27
if you want it to stay hot in the future, buy the steel braid wire kit instead of carbon..
just a thought???
Hugh MacKay
04-07-2005 13:46:12
arod: You'll probably buy it for less money at CaseIH and get a better product for the task at hand.
JOSSETTE
04-07-2005 13:34:42
70's chevy pickup with a 350 motor or bigger
PAULIH300
04-07-2005 15:50:01
 Re: 12 V coil, which one to buy at NAPA - farmall in reply to JOSSETTE, 04-07-2005 13:34:42
GM went electronic (HEI) ignition in the mid 70s,so you dont want that one....it goes inside the distributor cap and looks like a magneto coil.
Any coil will only put out what is asked of it.With new plugs,new cap/rotor,new wires (especially steel core),the system will not demand a high voltage of the coil.With fouled plugs and broken wires then it might ask for 20-30,000 volts...but only to try to fire the worn plug.It wouldnt raise horsepower or reduce fuel consumption.
In the old days,a gizmo called the "Spark Master Intensifier" was sold to go in between the coil and the distributor cap,its main purpose was to fake out the coil into thinking it needed to put out 100% power (it was a glorified resistor)all the time.The thought was to clean the plugs and get instant starts and more power.What actually happened was either the unit would fail and leave you stranded (until you unplugged it),or overheat the coil and pop it.They dont sell these anymore and now nobody subscribes to this theory to "Increase" power.
Even a HP coil will not change anything under normal conditions.
JOSSETTE
04-07-2005 16:07:11
 Re: 12 V coil, which one to buy at NAPA - farmall in reply to PAULIH300, 04-07-2005 15:50:01
he wanted something to work and cheap
thats all??!!
PAULIH300
04-07-2005 16:11:48
 Re: 12 V coil, which one to buy at NAPA - farmall in reply to JOSSETTE, 04-07-2005 16:07:11
He also mentioned "Hot"....as in performance coil.
NAPA sells them (they are chrome),but not worth all the extra bucks.A basic epoxy sealed coil would do just great.(keep everything else up to snuff too though).
