Farmall B parts {michigan}
fred {mud} hu
04-09-2005 03:39:28
I inherited a B from my sisterand need ta go thru it completely, not all at once {limited finances}.I'am looking for {if not a parts tractor}a belt pulley shaft. I'am goin ta repair the 3 broken teeth on it by buildin up with stick welder,but have worries about gettin the bevels correct on them . Any help or info would greatly be appreciated. Thankyou !!! Mud Hudson
old
04-09-2005 07:12:06
 Re: Farmall B parts {michigan} in reply to fred {mud} hudson, 04-09-2005 03:39:28
If you still are thinking about that front end parts we talked about, my wife thinks they will be able to hual them up your way in late June/early july
Reddog
04-09-2005 06:23:49
Where abouts in Michigan are you located ?????
Mike
Nebraska Cowman
04-09-2005 04:08:44
I'd have to do some numer checking but i believe there is one on the shelf.
6N's Short
04-09-2005 05:38:49
 Re: Farmall B parts {michigan} in reply to Nebraska Cowman, 04-09-2005 04:08:44
Got any Ford parts on those shelfs? I been meaning to ask.
Nebraska Cowman
04-09-2005 10:45:41
 Re: Farmall B parts {michigan} in reply to 6N's Short, 04-09-2005 05:38:49
Not on the shelf but I got a 8-N with a busted block to part out. got and extra motor with good block too. What do you need?
6N's Short
04-09-2005 11:09:32
 Re: Farmall B parts {michigan} in reply to Nebraska Cowman, 04-09-2005 10:45:41
At the moment, just the left side leveling arm for the three point hitch. The one on the right side has the crank for leveling but I need the left side without the crank. My tractor is a '44 2N and I don't know if they use the same part but they probably do. We could take some measurements if you think you have one. I'll try to check out what else I need too. Only just getting started on this tractor.
