706 steering, brakes and clutch/TA strange
andy R
04-10-2005 19:31:26
I was using my Farmall 706 today with a 4 bottom mounted plow and a four section harrow. Right away this morning I noticed the steering was making a noise and it sort of had a surge. Then it seemed as if the brakes were not 100% as at times there was quite a bit of free travel in the pedals. Then the tractor wanted to stop on the "high side" of the TA. Pull the TA back and away she went. So, I know this is all related to the hydraulic system that supplies the steering, brakes and TA. There was a time or two where the steering noise left. Actually manual steering then. Eventually everything powered up again with the same noise and surges in the steering. The transmission was low. I think I put in 2 gallons at least. That brought it up to slightly above add one gallon. What is going on here???? Do I have air in the system???? Does this oil get filtered on the right hand side??? Could the filter be restricting the flow of oil into the pump????? Help?????
Weldon
04-11-2005 06:35:01
 Re: 706 steering, brakes and clutch/TA strange in reply to andy R, 04-10-2005 19:31:26
Add more hyd. fluid. Fill to the " FULL" mark, at least. More will not cause any problems ( better to be above full if you run on steep hills like I do).Change the hyd. filter while you are at it.
P Backus
04-10-2005 21:50:53
It sounds to me like you need to change the hydraulic filter. Yes, it's the one on the R.H. side of the transmission, and no, I don't believe that all your trans, fluid will leak out when you take the cover off even though it looks like it will. A clogged filter will give the symptoms you described.
Paul
P Backus
04-10-2005 21:54:44
 Re: 706 steering, brakes and clutch/TA strange in reply to P Backus, 04-10-2005 21:50:53
The fact that you were low on hyd. fluid would be unrelated to the filter. Did the problem get better when you added fluid? I still think the filter is the first thing to change.
Paul
Hydrolic Pressure
04-11-2005 08:07:11
 Re: 706 steering, brakes and clutch/TA strange in reply to P Backus, 04-10-2005 21:54:44
I agree. The big question here is why you were down THREE GALLONS of hydraulic fluid. That's quite a bit to be down.
andy R
04-11-2005 15:23:43
 Re: 706 steering, brakes and clutch/TA strange in reply to Hydrolic Pressure, 04-11-2005 08:07:11
Thanks guys that is where I will start - filter and more transmission oil. Normally I do keep the oil at the proper level. It had sat most of the day before running an orbit motor on an auger. Little did I know it lost some oil out of the coupler. Thanks again for the ideas.
