type seat for 1932 F-20
okla kansan
04-14-2005 18:03:45
I tookn the seat off my junker 37 and mounted it on the 32 before thinking that it might not be the right one. It has the BIG spring under the channel that runs out to the seat, iffn that tells you anything. I know they made a couple of other style seats. The one that has a spring under a square bunch of iron and has a rod that can adjust into several notches to allow for weight is one. Ive seen that on 20s, and 30s, and Hs also. Ive had tem, and my uncles 41 H had one like that
Sloroll
04-14-2005 20:39:43
 Re: type seat for 1932 F-20 in reply to okla kansan, 04-14-2005 18:03:45
That is the seat that came standard that you mounted. The others are either special equipment or aftermarket affairs.
