Farmall M throttle/governor
Lane Corley
04-17-2005 15:12:26
There is no response to throttle movement on our Farmall M. The engine is running at about half throttle no matter how the throttle is positioned. The external linkage between throttle and governor housing appears to be okay. Any suggestions?
Farmall Teen
04-17-2005 17:33:42
 Re: Farmall M throttle/governor in reply to Lane Corley, 04-17-2005 15:12:26
We have had carbs get gunked up from setting around a long time. Might want to see if it is clean
MAGMAN
04-17-2005 15:27:17
SOUNDS LIKE THE CARB HOOK UP There is a tang from the gov that ingauges the throttle plate in the carb if its not put together right that will do that. Have you had the Carb off?
the tractor vet
04-17-2005 15:15:43
Broken spring inside the govener maybe a broken shaft and maybe the shaft to the carb is woren as i am not the one working on it . But that is where to start.
