live hyd pump for a M
super red
04-18-2005 15:47:52
Would a live hyd pump off a 400 fit a straight M or would I have to change the front plate on the engine so the holes line up ?
Boyd G
04-19-2005 16:14:01
 Re: live hyd pump for a M in reply to super red , 04-18-2005 15:47:52
In my earler comment I neglected to say that it makes a difference what kind of hydraulic pump you have. I know an M&W pump will fit the early Ms, while an IH pump will fit 1951 and newer Ms without changing the camshaft cover. I have a SM with M&W, A 51 M with an IH punmp, and am in the process of putting an M&W on a 47 M, and it does fit. Hope this helps. Boyd
Randy SE-MN
04-19-2005 05:35:39
The serial number break for the IH pump is 22082 and up. This number occured in 1950. Below that serial number the plate and cover must be changed or drilled. Randy
Boyd G
04-18-2005 18:40:20
If your M is 1951 it will most likely fit. Wish you luck. Boyd
TWL
04-18-2005 18:23:06
Don't forget the cam gear from a super or 400.I was told the m gear won't hold up.
Jay (ND)
04-19-2005 06:16:22
 Re: live hyd pump for a M in reply to TWL, 04-18-2005 18:23:06
yep - don't do this job without doing that
Jay (ND)
04-18-2005 17:18:29
not without some modifications - looking back, I wish I would have switched the front plate, makes for a much nicer job.
