H' Radiator, where to buy?
KevinH
04-18-2005 17:13:05
Ok guys, I've had enough of keeping a constant supply of water nearby to keep the leaky radiator full. Where is the most affordable YET good H radiator? This site? Thanks in advance, Kevin
El Toro
04-19-2005 02:53:42
 Re: H' Radiator, where to buy? in reply to KevinH, 04-18-2005 17:13:05
Try www.tractorradiators.com Their email is jd@tractorradiators.com or at
1-800-853-2651. Hal
Nebraska Cowman
04-18-2005 19:58:49
I should be able to find you a good used one.
Jeff In Ontario
04-18-2005 17:23:33
Kevin:
You can get them here or on Ebay; one word of caution .... some reproduction rads are not exactly the same size as the original ones were, thus making it hard to fit the grill and hood back on again.
Good luck!
Jeff
JOSSETTE
04-18-2005 17:18:53
get the sodder out and fix it
KevinH
04-18-2005 17:24:21
 Re: H' Radiator, where to buy? in reply to JOSSETTE, 04-18-2005 17:18:53
So much solder on it now I don't need front wheel weights! I think it's leaking around where the bolts go in the bottom.
