shift lever
iester
04-19-2005 17:48:04
Removed lever,Beefed up end,cleaned,painted and now ready to reinstall.(350 utility) Question is should I use wheel bearing greese to pack shifter pivot.Seems it had some sort of greese their before....THANKS...LESTER
janicholson
04-20-2005 09:01:19
 Re: shift lever in reply to iester, 04-19-2005 17:48:04
If you have Hy-tran fluid in the trans I would not use a fiber based wheel bearing grease. A light coat of lithium based (grease gun) grease would probably be ok. why not use a bit of trans fluid, that is what usually mists the pivot.
JimN
