hydralic fluid in ta.
jpl
04-20-2005 08:15:08
I bought a 58, 560Gas job and driving it home about 30 miles the hydralic hose started leaking, i was told the 3 bolt plate by shifter is where you put fluid in it. i pulled plug on left side and its full. seems this is rear to me. is the ta and hydralic fluid for 3 point in front of trans or is this the right place. dont have a manuel on it yet. thanks for feedback.
ejr-IA.
04-20-2005 08:52:58
 Re: hydralic fluid in ta. in reply to jpl, 04-20-2005 08:15:08
You found the right places for filling and fluid level check.The ta has a dry clutch in one compartment and a sprage and planet gears in another with the transmission oil for lube.All the oil comes out of the trans houseing hyd and powersteering .The PTO has seperate oil and check plug.They all take HYTRAN fluid.
jpl
04-20-2005 09:54:01
 Re: hydralic fluid in ta. in reply to ejr-IA., 04-20-2005 08:52:58
thanks for followup, when the fluid leaked out i wasmworried about the ta as it was rebuit 2 years ago. i was almost home and pump was whining, will use the tractor for pulling so dont need the 3 point, will taike off this stuff off, someone maybe can use it. i feel better now was worried. only drove 200 feet with the whine and shut it off. takes awile to get a manuel off internet.
