2500 series A wheel bearing #
pat,maplehillfrm
04-26-2005 20:47:52
I am not sure if this is old enough to be posted here , but I need a number for a race for the outside wheel bearing race on a International 2500 series A backhoe loader tractor. I have the number to the bearing it is 2689, I cant find the # on the race it is quite pitted, if it helps I have the #'s to the inside bearing and race they are 3578 on the bearing and 3525 0n the race , any help or a site that may help is appreciated , thansk pat
K.B.-826
04-26-2005 21:20:42
 Re: 2500 series A wheel bearing # in reply to pat,maplehillfrm, 04-26-2005 20:47:52
Try your local Case-IH dealer. Should be the same as a 574 Utility tractor. If you don't have a dealer nearby, a good bearing warehouse could probably figure that out for you. Also, John Deere dealer parts departments are really good at cross-referencing bearings.
pat,maplehillfrm
04-26-2005 21:27:48
 Re: 2500 series A wheel bearing # in reply to K.B.-826, 04-26-2005 21:20:42
thanks, Ih case sent me away .said there were many applications , I think he was just bored. I have the bearings coming, but needed to order the races after I removed them, I looked at timken bearings and I think I foubnd that the race is a # 2631, going to the truck place tommorow and have them check with there supplier for the race ,thanks pat
El Toro
04-27-2005 07:34:09
 Re: 2500 series A wheel bearing # in reply to pat,maplehillfrm, 04-26-2005 21:27:48
The Timken outer race cup number 2631 shows the
Timken cone as 2684 in my Timken book. Hal
