farmall c/ three-point hitch
Donald Gallegos
04-27-2005 09:49:56
Does anyone have an aftermarket three point hitch on a Farmall C? How do they work? Are they worth the investment? I have a C that I would like to use three point implements on. Appreciate any feedback.
donald gallegos
04-27-2005 14:14:12
 Re: farmall c/ three-point hitch in reply to Donald Gallegos, 04-27-2005 09:49:56
Thanks for the feedback!! I love my "C" and would like to continue using it with three-point implements.
Dave_Id
04-27-2005 10:04:47
Saginaw County Tractors has one for the Super C, C that I would recommend all day long. An extra valve is required for it, and a small manifold slipped in behind where the hydraulic pipes hooked to the Touch Control Unit for the return. All of these items can be supplied by Saginaw. Worksaver also has one, but they lift right off the rockshafts, so you have a rod running by the clutch pedal..
I bought the Saginaw, the only drawback for either one is the cost of shipping. If you live in Michigan, you have it made.
Tommy Pierce
05-01-2005 21:22:13
 Re: farmall c/ three-point hitch in reply to Dave_Id, 04-27-2005 10:04:47
I have done all three options on a Super C. The work saver isn't worth your time. Saginaw is the ticket but cost alot ( Shipping ) The two point hitch adaptor kit is good but has limits. Go with Saginaw you will be glad you did in the long run. I had rods by my leggs on the work saver type
