Order Farmall Cub Parts Online
Cub rear wheel spaceing worth the work or not.
Steve in Mo
05-02-2005 12:42:02
Well I gave in and purchased a 1958 Cub so that I had something with a sickle bar. Used it first time this Sunday. My land is a not all that flat and I found the Cub to be a little tippy.I plan to put new tires on the back right away, do you all think spaceing the tires/wheels all the way out is worth the effort or not? Thanks
Bigdog
05-02-2005 14:57:09
 Re: Cub rear wheel spaceing worth the work or not. in reply to Steve in Mo, 05-02-2005 12:42:02
Steve, dish the rear centers out and leave the front alone. This will give a lot of added stability. That's the way I run my cub with the sickle bar attached.
old
05-02-2005 14:27:04
Well since I'm in about the same area that you are in I have only one word for you. YES!!
Nat
05-02-2005 14:01:15
It'll be a whole lot more stable on those hills.
My Cub is set as narrow as possible to get the wheels in behind the 60" mower deck. I just use a little "body english" to keep the old girl upright on the side hills, though it hasn't really felt like it was going to tip over.
The engine side is always on the uphill side of the equation, which helps I think.
muskrat
05-05-2005 12:08:33
 Re: Cub rear wheel spaceing worth the work or not. in reply to Nat, 05-02-2005 14:01:15
I have never had a problem with the wheel spacing on the cub. The front is out a couple of notches but the back is on the standard sitting. I have no trouble with it being tipping when I went over uneven ground
