706 Block
Farmallion
05-04-2005 10:40:18
Im having the head milled this week, i put 3 different straight edges i have on it and got 3 different answers so i don't have a good enough straight edge to gauge anything. I hope the block is not the problem, is it unlikely that the block will be warped? the head gasket was bubbling between the head gasket and the block but i don't know if that means anything.
the tractor vet
05-04-2005 18:21:17
 Re: 706 Block in reply to Farmallion, 05-04-2005 10:40:18
The block will warp but unless ya got a true stright edge and the sleeves out it is real hard to tell . Don't worry about the block and tell the machinest to only take what is needed to clean it up , don't get or let someone talk ya into millen .020 or more off because you will have more problems then you can think of somewhere around .007 to .015 is enough . Do like i told ya before get a 1/2 -13 bottoming tap and chase all the bolt holes to the bottom clean the threads , wash out the holes with either or brake clean and blow dry lube the bolts and washers use some guide studes to align the head as you set it on the gskt use copper coat toqure in a three step pull down ( 45 ft. lbs .-75 ft. lbs. 95 ft. lbs. then go back over again then set valves start tractor warm up to operating temp use a victor gskt. re toqure after hot reset valves put the valve cover on and run it. Done deal.
jossette
05-04-2005 13:26:57
make you check for cracks
captaink
05-04-2005 10:59:48
When you combine metal, heat, cooling and repitition, anything can happen over time even warping a block.
All that the bubbling between the gasket and the block means is that the gasket is leaking in that spot, not necessarily due particularly to the head or block.
If the head was warped significantly, having it planed should (no guarantees here) take care of the problem.
