504 utility 3 point problem
Randy in CO
05-05-2005 19:01:18
THe factory three point on my IH 504 utility begins to drop after reaching its set position. About every 20-30 seconds it catches itself and reassumes the original position. It lifts and lowers and controls fine. What is my problem? Is it in the control valve circuit? or in the hydraulic system for the lifting of the lift arms?
Thanks
TDK
05-06-2005 19:38:33
 Re: 504 utility 3 point problem in reply to Randy in CO, 05-05-2005 19:01:18
Randy. here's what I found in the B/R manual for your tractor. 1)Leakage past check valve in the main control valve. 2) Cylinder relief valve leaking or dirt holding the ball off it's seat. 3) Cyl. o-ring damaged or cyl. scored. 4) Drop poppet sticking.(Dirt or excessive o-ring friction.) 5)Check valve actuating rod adjusting screw misadjusted. * In the case of #2 you can do this - Lower hitch to about 2" from ground. Lift the hitch by hand to top of it's travel & drop it.
Randy in CO
05-06-2005 20:02:28
 Re: 504 utility 3 point problem in reply to TDK, 05-06-2005 19:38:33
TDK, thanks so much for the response. I will try as you suggested, I assumed that overhauling the cylinder was the only choice thanks and I will let you know what I find.
Thanks again
Randy
