M Transmission Question
Paul A.
05-09-2005 04:08:58
Hi, I am trying to remove the countershaft on my M, to change a damaged 4th gear. Is there an easy way to get the snap ring off the rear of the countershaft? I have removed the brake shaft (so I can see the snap ring), but the snap ring pliers I have will hardly budge it. Is there a heavier duty pliers that work better for it? Thanks, Paul.
KIrk in MN
05-09-2005 05:59:55
 Re: M Transmission Question in reply to Paul A., 05-09-2005 04:08:58
Yes there is one with a screwdriver type handle that you turn to open and close it. Alot stronger than the plier type but more expensive too.
