Farmall M weight
Rick2
05-13-2005 11:46:35
Can anyone tell me the approx weight of a Farmall M. Need it to give to shipper.
Thanks
Doug in OR
05-14-2005 09:43:59
 Re: Farmall M weight in reply to Rick2, 05-13-2005 11:46:35
First, you cannot believe the listed shipping weights. The manufacturers understaded actual weight regularly.
I had an M down to 5000 punds (including me) for pulling purposes. Hydraulic pump was removed. The stock cast wheels were replaced with pressed steel. No PTO. Some fluids removed. Other things too. A stock M probably weighs between 5250 and 5500 pounds.
CNKS
05-13-2005 18:37:46
Hard to get one under 5000, fluids, wheel weights, narrow or wide front, loaded tires, etc will push it to 5500 or more.
jpl
05-13-2005 18:55:06
 Re: Farmall M weight in reply to CNKS, 05-13-2005 18:37:46
yep it is but can be done, i weigh 240 and weighed it at princton pull with no weights and weighed 4623. i could lose about 1oo lbs with changing the drawbar, but i run 5500 and 6500 class anyway. just my 2 cents worth. good luck to all pullers this season.I forgot i got a 52 m.
F-Dean
05-13-2005 11:50:24
According to Guy Fay's book, 4,910 pounds.
