I need some suggustions on 404 hydraulics
Jrry
05-15-2005 04:33:18
I purchased a rockshaft with three point to replace the bareback that came on mine, The old one operated a sicle mower. After I installed the three point I have no hydraulics at all not even the sicle mower. The hydraulics are not even trying to work. The one I put on is supposed to be good and it is exactly like the old one except it has the three point lift arms. Any suggustions?
Jeff311
05-15-2005 19:26:01
 Re: I need some suggustions on 404 hydraulics in reply to Jrry, 05-15-2005 04:33:18
Jerry, This is Jeff in INDY...might try taking the large line loose on the inlet side of the filter and rigging a make-shift oil supply to force feed the pump to help prime it. I think once you get pressure flowing and suction started, the oil pickup that you installed on the rear top cover should prime itself. Might also be a blocked bypass valve and sounds like the vet may be able to walk you through those scenarios.
Jrry
05-16-2005 09:03:22
 Re: I need some suggustions on 404 hydraulics in reply to Jeff311, 05-15-2005 19:26:01
Jeff, I'll try that. thanks
the tractor vet
05-15-2005 13:58:37
Now that is one I H tractor that i have never worked on so you'll have to give me some time to dig up the Hdy's scymatics and i post later on that one but i think that ya got a line wrong or a stuck valve , not sure on how the oil get from the transmission to the pump and from the pump to the rockshaft housing , but i will look .
Jrry
05-16-2005 09:00:39
 Re: I need some suggustions on 404 hydraulics in reply to the tractor vet, 05-15-2005 13:58:37
I'd appreciate any help on this. Maybe it is a stopped up valve but not sure.
