wide front end same on a H and M
Kevin Farmall
05-16-2005 17:08:06
I just bought a h with a wide front end and I"m just wondering if it will fit on my Super Md? Thank-you
Steven@AZ
05-17-2005 19:53:31
 Re: wide front end same on a H and M in reply to Kevin Farmall, 05-16-2005 17:08:06
The steering arm and back spacing plate are different. Otherwise it will work just fine.
Not worth spending a lot of time to find one from exact tractor. I'm sure a junkyard will have the plate and steering arm for not too much...
r4etired
05-16-2005 18:38:22
M has a 20in frame, H has an 18in
Paul in Mich
05-16-2005 17:41:11
Kevin, The axle tube and spindles are the same as are the tierods and wheel castings, however, the steering arm mounting and the main reciever mounting plates are different from the H to the M. I suppose a mounting plate can be made as well as the steering arm braciet, but its much easier and just as cost effective to buy the right wide front assembly for the right tractor.
