Question about a International IHC Model A
Barb F
05-17-2005 06:36:06
Hello my name is Barb, I am
hoping someone might be able to help me..... .
I am writing on behalf of my Uncle, He has just purchased a International IHC Model A with a serial # IAA 95261.
We are looking for any information pertaining to this tractor, mainly the
year.
He is planning on restoring it and showing it in collector shows here in
Winnipeg Manitoba.
I'm not sure if you have info that would be useful, but I thought it would
be worth a try.
Thanks!
Barb Fuhr
05-18-2005 06:31:34
 A THANK YOU for Question about a International IHC in reply to Barb F, 05-17-2005 06:36:06
A big THANK YOU to all whom responded to my initial question. My uncle appreciates it very much, as do I! I am going to keep checking back to see if any other info comes up and I am sure he will get me to post any questions he may have also.
Again THANK YOU!
Till next time - Take care,
Barb!
Paul in Mich
05-17-2005 16:30:58
 Re: Question about a International IHC Model A in reply to Barb F, 05-17-2005 06:36:06
Barb, YOur Uncle has aan industrial version of the Farmall A. The serial number you submitted suggests that it is a 1944 model. While it is very simmilar to the Agricultural version of the Farmall A, there are some distinct differences. First, it was considered an International, not Farmall, and the side decal would indicate that. It was also equipped with a square tube front axle instead of the round tube found on the Farmall version, and it also had a reinforcement bar which extended from the front axle to the torque tube. The IA also had a foot excellerator pedal. The default color was Farmall red, however, since many municipalities, state DOT, airport companies, and military bought the industrial A, they could be ordered in just about any color the fleet so ordered, from yellow to orange, to olive drab, grey, as well as red. Many were equipped with PTO, depending on the intended use, but many came with no PTO, and very few came with pulley. They were used a lot for mowing along highways and along ditchbanks. There are no actual figures as to how many were produced as the serial number sequences were dove tailed in with the Farmall A, AV, B, and BN. I suspect also since you do not include a suffix with the serial number that it may be a distillate model. If it is or was equipped with an extra one gallon auxillary gas tank and radiator shutters, it would confirm that, however, through the years, those distillate tractors were converted to gasolene, and often times the small gas tank removed. It may even with the tank removed have the extra hole in the hood on the right side opposite the air cleaner. If it were factory gasolene, it would have X1 suffixed to the serial number. While many farmers don"t find the Industrial A quite as collectable as the Farmall A, they are still very desireable tractors, and if complete, make great show pieces as well as functional tractors. I hope your uncle enjoys his newest find, and is able to come online with any questions. There are lots of guys here who have much experience with these tractors, so there are few if any secrets, but lots of input. Enjoy.
gene b
05-17-2005 18:58:17
 Re: Question about a International IHC Model A in reply to Paul in Mich, 05-17-2005 16:30:58
Just finished working on an A that was a dual fuel engine and it did not have any other numbers on the serial plate or engine with x1 or anything else. H ave been around several of these and none had anything else but the prefix and then the serial number. Where does your info come from?
Paul in Mich
05-17-2005 20:42:12
 Re: Question about a International IHC Model A in reply to gene b, 05-17-2005 18:58:17
Gene, serial number suffixes were used on the letter series tractors to define many different options. The most common designation was the fuel configuration. Gasolene was identified by suffix X1, Kerosent X or X3, and distillate no suffix or X17. Since you have no suffix, your tractor would be a distillate model. You refer to "Dual fuel". This is a generic name given to any configuration which required starting on gasolene and running on either distillate, or kerosene. My source for this info is "Farmall letter series tractors" published by Guy Fay and Andy Kraushaar. While there are no doubt many other sources for the same information, this book is probably the most reliable as it was researched back to IHC archived material.
gene b
05-19-2005 10:51:24
 Re: Question about a International IHC Model A in reply to Paul in Mich, 05-17-2005 20:42:12
Yes it was on some but not on any As or Bs and i have seen several.
Dave_Id
05-17-2005 10:35:57
If I'm not mistaken, the I in the IAA means you have the industrial version. Is it painted yellow? I believe it has a heavy duty front axle
Barb F
05-17-2005 12:19:58
 Re: Question about a International IHC Model A in reply to Dave_Id, 05-17-2005 10:35:57
I will have to call & ask my Uncle, it's his tractor and he does not have a computer.
RustyFarmall
05-17-2005 07:12:30
It appears that the tractor is a 1944 model. You have come to the right place, a wealth of info is available here. There is even a fellow from Canada who is very knowledgable on the smaller Farmall tractors, he just may jump in here in awhile.
Barb F
05-17-2005 07:28:04
 Re: Question about a International IHC Model A in reply to RustyFarmall, 05-17-2005 07:12:30
RustyFarmall
Thank you for the info - I am sure my uncle will have more questions to follow in the coming months as he starts to restore his tractor.
Thanks again!
Have a great day!
Barb
Nat
05-17-2005 10:56:37
 Re: Question about a International IHC Model A in reply to Barb F, 05-17-2005 07:28:04
You've really gotta teach him how to use the Internet...
