300U PTO problems
old
05-18-2005 06:38:38
Friend has a 300U that he says the PTO runs slow and also get a lot of noise in that area. I have tried to adjust it as per the book but it doesn't seem to be working as it should both the adjusting and the PTO. From what we know this tractor may have been used to run a saw mill. I'm gues it my need new bands, I'm I on the right track or is there something else that may be wrong??
Thanks
Aces
05-18-2005 08:35:00
 Re: 300U PTO problems in reply to old, 05-18-2005 06:38:38
Old the 300U would have a double pand type PTO one for clutch one for brake, could be interchanged when the clutch got bad, but after all there years who knows. As for the noise they did make some noise and had a disconnect in the TA housingto stop the pto when not needed for a long time. You can pull the back cover off and change the bands with removing the pto unit. You have to remove the small round in the center with the three hex cap screws then a nut and lock on the pto shaft, then the plate that covers the whole pto. Some times not all the easy. Good lock.
